Lolu chungechunge lwabekwa kunqolobane. Uyacelwa ubuze umbuzo omusha uma udinga usizo.
[RESOLVED] Firefox not fully maximized, when using "small icons" appearance for taskbar.
  • 1 baphendule
  • 2 zinale nkinga
  • 2 views
  • Igcine ukuphendulwa ngu ideato
I've included a screenshot in which you can clearly see the blue part, that comes from the desktop, Firefox is fully maximized. I was wondering if there is a way to fix this.
Edit:
It seems to work after restarting or logging off, so that's fixed now. Hope it helps anyone with the issue.
I've included a screenshot in which you can clearly see the blue part, that comes from the desktop, Firefox is fully maximized. I was wondering if there is a way to fix this. Edit: It seems to work after restarting or logging off, so that's fixed now. Hope it helps anyone with the issue.
Okulungisiwe ngu SRey
Isisombululo esikhethiwe
Hello SRey, it is great to solve the problem, please post a reply to your question and write the solution again in that reply, then mark your reply as solved (to help others with same problem, only the solved questions quickly displayed in google search :-) )
thank you
Funda le mpendulo ngokuhambisana nalesi sihloko 👍 0
Isisombululo Esikhethiwe
thank you
